Windows 10 Image
Old 07-06-17, 11:48 PM
kolias's Avatar
Received 3 Votes on 3 Posts
Windows 10 Image
I have a Dell Inspiron since December 2015 with Windows 10 and I did a system backup on a USB when I got it.
Last March I had to send it back to Dell for repairs and came back with a new Windows 10 installation because they changed the motherboard. Trying to do again a new system backup (image) I noticed the only options are to backup to an external HD, DVD’s or network.
Is it possible to do a system backup to a USB or the newer Windows 10?
Old 07-07-17, 06:06 AM
Isn't a USB also considered an external HD with a drive letter?
Old 07-07-17, 06:54 AM
kolias's Avatar
I used the same 16GB USB I had the previous windows10 backup which I first re format with NTFS and I forget the exact words but windows didn’t like it. I first did a quick re format on the USB and then tried with full re format and got the same message.
As I mentioned the option for an image backup now are
An external HD
DVD’s or
Network
I suspect since it says “external HD” and not “external HD or USB” you can’t use a USB
Old 07-07-17, 07:03 AM
What happens if you take an IDE or SATA HD & connect it with a USB external HD enclosure?
Old 07-07-17, 08:54 AM
kolias's Avatar
I do have a 1.5TB USB Seagate HD but my question was why I was able to backup windows10 system on a USB before and now I can’t.
Using the Seagate USB HD I have to make a bootable partition on it with the windows10 rescue utility and then do the system backup or since the Seagate is networked I could do the backup by trying the “Network” option from the win10 system backup which I didn’t try.
Best I would rather try the DVD’s option since I don’t want to mess up my Seagate with a bootable sector however I was hoping someone here would have been able to answer my original question
Old 07-07-17, 09:17 AM
I haven't tried to create a bootable backup in Win 10 & probably won't. Since Windows OSes have recovery partitions now & since I have a recovery DVD, I see no need. All that's needed is a file backup.
Old 07-07-17, 10:08 AM
kolias's Avatar
I agree however the purpose of a system backup is you are backing up that recovery partition in case your HD fails.
Not likely but if it happens you will have no OS to install on your new HD
Old 07-07-17, 05:35 PM
H
Received 90 Votes on 79 Posts
I'll make a wild guess that for some reason, your 2nd installation of Windows 10 needs more than 16 gigs for the backup...
If it's the OLD drive, but NEW motherboard, you probably have a huge "windows.old" folder which has the entire 1st Win 10 installation. That suggests you're basically backing up 2 copies of Win 10.
Select C:\, right click for properties, tools, general, disk cleanup, system files.
Check if you have a mega-gig system backup.
Old 07-08-17, 06:54 AM
kolias's Avatar
That’s an excellent idea Hal_S which I never thought about it and makes sense
Somehow I think I did a disk cleanup but don’t really remember
The Dell belongs to my wife and when she comes back today I will check it out
Old 07-08-17, 04:35 PM
kolias's Avatar
The recovery partition on Dell is 10.6GB so as I guessed I had deleted the old win10 when I did a disk cleanup.
