broke MicroSd Card
Old 01-27-18, 10:01 AM
B
broke MicroSd Card
I got a 512GB card cheap from wish. When I got it, it was full of bad sectors and would not read/write properly. I ran chkdsk first then disk part to format in NTFS. While it was formatting I accidentally crashed my computer and had to restart. Now when I insert the card nothing recognizes it is there but I do get a ghosted image of a drive in windows explorer. I have tried Disk Management but it does not see the disk, nor do a few partition programs I have.
Old 01-27-18, 11:28 AM
W
Received 21 Votes on 20 Posts
Replace the card..............................................
Old 01-27-18, 02:16 PM
O
I stopped reading after "I got a 512GB card cheap from wish. ".
Old 01-27-18, 02:23 PM
H
Received 108 Votes on 94 Posts
More likely, you got an 8GB sd card, painted to say 512GB,
hacked to have a valid 512GB logical directory structure,
The card reports 512GB to Windows, to checkdisk.
When you try to format it, it crashes.
There are a few programs that will check the physical size of the sd card.
https://www.raymond.cc/blog/test-and...-with-h2testw/
Once you know the actual size, Login as admin,
hit Win+X and select "Disk Management".
That should give you a menu to re-partition the card, then reformat the card to the correct size.
Old 01-27-18, 03:24 PM
B
Well I got it for free so I am not out anything if it was hacked or faulty. But I would like it to work some if possible.
I will try the programs but aren't they predicated on windows being able to access the card?
Old 01-27-18, 03:31 PM
B
I downloaded and ran Fake Flash Test but it does not see the MicroSD. I am trying to get to the part where it can see the drive.
Old 01-28-18, 10:39 AM
A
Received 2 Votes on 2 Posts
The drive is likely corrupt.
Try this. Start a command prompt and type DISKPART
It'll list all the disks on your system. You should see the 512gb disk with a number next to it.
Type "select disk (number shown)"
Type "clean"
This will clear all the partition data on the drive.
Type "exit" to return to a command prompt.
Now check disk management for the unallocated drive.
