BMP to PDF converter shrinks size of doc?
I have a BMP file drawing in paint that i want to change to a PDF. I have used several online converters and they shrink the drawing from 36x24 to 18x12. Is there a way to keep it the correct size?
skeeter
skeeter
If you're running Windows 10, you could try "printing" the BMP to a PDF file and see what happens. If the physical size is changing, apparently the online coverters are changing the ppi (pixels per inch) of the original drawing.
Well the file was originally a PDF that was converted to a BMP. When that happened it increased in size and i reduced the size back to original size in paint. i did my editing and then converted it back to PDF and now it's smaller than the original. Guess i shouldn't have reduced the size in the first place. But then that makes it hard edit things in the image to the correct size i want. It's a quandry.
skeeter
skeeter
Not really my area but have you tried converting to png then PDF.
https://www.reddit.com/r/discordapp/...actual_images/
Ok it seems that i am using different versions of pdf converters and they resize at a differnet rate. My original pdf is version 1.6(acrobat 7.x) and the online converter uses version 1.3(acrobat 4.x). when i convert to bmp then back to pdf i end up with a different size doc. Is there a way to work around this problem?
skeeter
skeeter
Print to pdf does give the option for a custom size, 36x24.
Converting from png to pdf always comes up as a corrupt file.
Could i resize the pdf after converting it from a bmp?
skeeter_ca
skeeter_ca
