Erratic internet connections
Old 03-13-19, 08:18 AM
Norm201's Avatar
Received 41 Votes on 41 Posts
Should I be concerned and contact my ISP?
Lately I have been getting intermittent connectivity to the internet. They last from seconds to maybe up to a minute. My computer tells me I'm connected but I get these "loading" the web site including this site. Here is a pic of the latest broadband speed test. The problem is most persistent viewing Spectrum live TV on the computer.
Old 03-13-19, 09:01 AM
Received 141 Votes on 134 Posts
Yes, contact your provider. They will likely tell you nothing is wrong on their end, maybe tell you to re-boot your modem then ask if you want to schedule a paid service call with one of their technicians.
Old 03-13-19, 12:01 PM
Received 11 Votes on 9 Posts
How old is the router?
How many devices on the network?
I've seen problems with 10-year-old routers which have tiny NAT tables, they accumulate lots of IP addresses and then can't load new ones.
Any trees down or telephone pole problems nearby?
Old 03-13-19, 12:50 PM
Norm201's Avatar
The router is about 3 years old (A LINKSYS EA6100).
But, yes I do have a number of items tapping off it. But until now I never had a problem.
Probably should do a restart. But I have had power outages this past winter which is pretty much the same thing as a restart.
But looking at the latest speed check, I think Spectrum is throttling back more and more.
Old 03-14-19, 07:43 AM
If you have multiple Win-10 machines, check that Windows-10 "update over lan" is enabled. This prevents, say, 4 computers all downloading the same 4 gig upgrade at the same time.
Also helps (in Win-10) to open task manager, click Performance tab, start "Resource Monitor" and see what is actually happening on network...
Old 03-14-19, 08:34 AM
Dawter's Avatar
When I saw the word SPECTRUM I said, AH HA!
I just got off the phone with them because of intermittent internet.
The Techs have been out twice to fix it at no charge. It's still not fixed.
First they said there's water in the line...came out- supposedly fixed it up in the air on a boom(?)
Still intermittent at the most inconvenient of times.
Sent another Tech out. He replaced the line from the house to the pole as he said it was old.
Today on the phone a tech said it may be the router.
I rebooted the router and viola! I have internet.
Old 03-14-19, 08:46 AM
What Service are you paying for?
There is a way to look at your signal strength (and they can do it remotely) from your Cable Modem.
A bad connection or too many splitters can cause a problem.
https://www.speedguide.net/faq/what-...idered-good-78
Old 03-14-19, 09:01 AM
Dawter's Avatar
I have internet only with Spectrum. There is one splitter on my cable line because it was too short to reach my desk.
The Spectrum techs have both said everything in the house is good. They too checked the connections.
I will take a look at the link you provided.
To me, my speeds are good. I don't need it any faster. It's only the connection I'm having fits with. Thank you for your help.
Old 03-14-19, 10:57 AM
Check for a firmware update for your router.
How are you connecting to the internet? Wireless or wired?
Old 03-14-19, 01:29 PM
Norm
Look at your modem manual and you should find an adress you can use with your browser to access some of the modems internal statistics. Example of address you type in your address bar:
http://192.168.100.1
That should allow you to see some of the modems data concerning signal strength, power levels, noise, etc. That might shed some light. There are known acceptable limits for these values and out of range values would indicate a problem.
Example of a report, which is a snapshot in time:
Old 03-14-19, 02:28 PM
Dawter's Avatar
If you're asking me I connect by cable.
Old 03-14-19, 03:44 PM
Norm201's Avatar
I'm connected both by Ethernet (main computer) and wireless with all my cams and laptops (3 laptops mine, wife and daughter).
Yes I have access to the modem stats, but they all seem normal. The only questionable thing is the speed as I pictured in my 1st post.
BTW...I did hear that Spectrum was in fact having some technical difficulties in my area this past few days. I'll wait and see.
