Toshiba laptop: broken key
Old 03-27-19, 01:39 AM
P
Hello, I have a Toshiba Tecra z40 laptop, the "E" key has broken, not the key itself, which seems intact, but one of the four anchors attached to the keyboard base.
All tutorials I found are aimed to replace a broken key, which is not my case, in my case, one of the four hooks/anchors that hold the key to the base, is broken and can't hold the key in its place. You can see it in the picture, it's the top right hook.
Do I have a repair option other than substitute the complete keyboard? (which I don't know if will be possible as Toshiba is not making laptops anymore)
Old 03-27-19, 03:18 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Yes google lap top keys there are several sites that sell keys and the hinge under it. here is one I used.ust gooled it and found several sites that were cheaper. Mine was about 6 or 7 dollars.
Old 03-28-19, 06:40 AM
P
That's what I'm saying, I don't need a new key, I need a different solution
Old 03-28-19, 07:45 AM
pugsl's Avatar
New key comes with hinge to attach. or do what I did use a bit of double sides tape to stick key on. .
Old 03-28-19, 08:19 AM
Shadeladie's Avatar
Super Moderator
Received 119 Votes on 94 Posts
Or try a dab of hot glue or a super glue.
Old 04-01-19, 12:18 AM
P
Hi, sorry for the delay, it took some time to get double side tape.
- Super glue and hot glue didn't work, the gum button is too smooth and slippery and glue doesn't fix, so this solution does not work.
- Double side tape: so far is doing the trick, the key press is not easy or comfortable but so far is working.
Thank you.
