flickering streaming TV picture.
Old 11-06-19, 07:23 AM
Norm201's Avatar
Received 77 Votes on 71 Posts
Maybe someone might be able to hazard a guess as to what is going on.
I use two monitors (TV’s actually) for my computer set up. On one I do my main thing (browsing, spreadsheets, forums, etc…). The other is mainly for TV show streaming or SiriusXM. I have Spectrum as my Internet server. I will typically use Chrome or VIVALDI browsers to watch the TV. As of late the video pixelates, flickers and jumps on the TV streaming. Even if I use Firefox. It even happens when I use the “main” monitor. All other electronics using the Internet signal appears to be working fine.
Is this a poor signal or what?
Old 11-06-19, 08:28 PM
Received 379 Votes on 356 Posts
As far as I know..... Vivaldi is a Chrome based browser.
What TV are you trying to stream...... networks ?
Old 11-07-19, 06:08 AM
Norm201's Avatar
Yes, any current TV program (FOX News mainly ). This just started about a week ago.
Old 11-07-19, 06:32 AM
Received 28 Votes on 23 Posts
Sounds like a bandwidth issue.
Try changing the settings from "auto" to some lower rate, see if that makes a difference.
Also, some cable-tv providers seem to throttle video-over-internet for channels they broadcast. I can't say for certain, but I HAVE noticed that with VERIZON, that streaming the local ABC/CBS/NBC/FOX stations in a browser from the webpage of those stations tends to be jerky, stutters and sometimes stops, but those same stations work fine when viewed from the VERIZON webpage.
Old 11-07-19, 06:58 AM
Norm201's Avatar
Hal, What do mean by change from auto to a lower rate? What setting are you referring to?
Old 11-07-19, 07:22 AM
Received 34 Votes on 33 Posts
Are both browsers up to date?
Are your video drivers up to date?
Old 11-07-19, 07:33 AM
Norm201's Avatar
Yes to both questions. I'm currently trying to locate my bandwidth settings on my router to make adjustments.
Old 11-07-19, 09:23 AM
Are you hard wired or using WiFi?
Also have you run a speed check?
Old 11-07-19, 09:48 AM
Norm201's Avatar
Hard wired and speed checks out fine. Same as the last six months
Old 11-07-19, 12:20 PM
Many browsers and sites have a "quality" setting for video, AUTO will use as much bandwith as is available, settings generally listed by pixels, e.g. 4k is 4320,. HD is 1080, half-hd is 720p, while TV is 480
Old 11-07-19, 02:03 PM
Norm201's Avatar
Problem identified but not resolved!
Called Spectrum. They are aware of the problem and it's on their end. Apparently many people have complained. Their engineers are working on the problem. For what ever reason the raw signal that would normally go through the cable box and filtered from there for cable TV is not being filtered on their Internet signal via streaming. He told me it started with the News feeds including their own and has since migrated to other channels. He told me to periodically check it. When no more pixlatting and flicker stopped , that's how I'll know it's fixed. He did not have any time table.
At least I know it's not equipment!
Old 11-08-19, 06:35 AM
Norm201's Avatar
Funny how a day later problem is fixed!
Old 11-08-19, 10:56 AM
Received 29 Votes on 28 Posts
Problem? What problem? We don't have record of any problem.
CircuitBreaker voted this post useful.
Old 11-08-19, 03:12 PM
Received 1 Vote on 1 Post
Lol! @ Zorfdt so true
I also have the Charter (AKA Spectrum) triple play
