Server I/O Error
Server I/O Error
I have a Dell T110 II server with three drives in a raid. The purpose of the raid was in case a drive went down it would be a simple matter of replacing the drive, rebuilding it and off we go. One of my software packages can't run because it says some of the files are experiencing I/O read errors.
Can anyone help me understand what is going on?
Thanks
Thanks
Make sure you understand the differences between RAID 1, 3, 5 and others.
Also, regardless of your drive configuration, make sure you have a good backup strategy. RAID is definitely not a replacement for good backups. I don't want to tell you how many servers I've seen die and lose or almost lose data even with RAID running....
