Easy CD Creator Pukes with Data CD
Old 06-18-01, 06:25 PM
OHKP55's Avatar
Unhappy
Since I loaded a patch from Microsuck, Easy CD Creator 4.02 will not burn data files. Audio are fine. It just pukes with data. The error I get is:
CREATR32 caused an invalid page fault in
module JOLIET.DLL at 018f:02021021.
Registers:
EAX=00000000 CS=018f EIP=02021021 EFLGS=00010216
EBX=00000008 SS=0197 ESP=073afbe4 EBP=073afbfc
ECX=00000000 DS=0197 ESI=00000019 FS=66af
EDX=00952460 ES=0197 EDI=00951bc0 GS=0000
Bytes at CS:EIP:
8b 48 30 83 c1 01 8b 55 ec 89 4a 30 8b 4d 08 ff
Stack dump:
073afe08 00000000 ffffffff 073afe08 02030d39 ffffffff 073afe14 0202b732 00952460 008f17a8 00923240 78037118 073afc58 7800cc37 00000009 00000001
Suggestions?
Old 06-19-01, 04:40 AM
Uninstall easy creator, reboot the computer, then reinstall, reboot the computer.
Let us know if that helps.
Old 06-19-01, 04:36 PM
OHKP55's Avatar
Easy CD Creator Fatal error
already did that. No luck. can't even get direct-cd to work. 'unsupported cd-rw' error.
Old 06-20-01, 04:11 AM
I don't yet have an answer for this one, but am trying to do some searches to see if I can come up with anything, I would like to ask though what was the patch that you downloaded from microsoft for ? What is your computer specs, cpu ?, memory ?
Old 06-20-01, 05:31 PM
OHKP55's Avatar
Talking Easy Cd Puke Fixed
Success. I ran Norton Clean Sweep, Norton Registry Editor, and RegClean. I whacked every reference to Adaptec, Easy Cd and Direct CD from the registry and my hard drives. Rebooted and reinstalled. It works. I even was able to load the 4.0 to 4.02 patch with no trouble. Thanks for your help. I guess everyone needs to manually search the registry and the harddrives to make sure all program references really are deleted when a program is "uninstalled".
Old 06-24-01, 08:52 PM
Question
What Operating system is it? IF M.E., that might be the problem as Millennium Edition is incompatible with anything non-Microsoft written before last week.
-Chris
"I'm serious!"
Old 06-24-01, 09:12 PM
He apparently has solved his problem.
I've never as yet had a problem with windows me being incompatable with software, or at least anything that I have had used.
Trackbacks are On
Pingbacks are On
Refbacks are On
