batteries
Old 06-09-23, 01:13 PM
P
Received 6 Upvotes on 6 Posts
batteries
When I use rechageable batteries with a key board they are fine. If I use them with the TV remote they don't work. Is it because they really have 1.2 not 1.5 volts and are not stronng eenough to do some heavier work?
My regular 1.5 store batts work with everything.
Top Answer
06-09-23, 02:04 PM
PJmax
PJmax is offline
Received 3,593 Upvotes on 3,222 Posts
NiMh rechargeable batteries are considered 1.2vdc.
Most devices will run ok on the lower voltage..... some will not.
Old 06-09-23, 01:41 PM
B
Received 258 Upvotes on 230 Posts
1.2 to 1.5 vdc is normal for AA and AAA batteries. Depends on the material they are made from, type and date of manufacture. AAs have a higher milliamp-hour rating than AAAs.
Old 06-09-23, 01:50 PM
P
I am not battery savvy. Does that explain my first post?
Old 06-09-23, 02:04 PM
Davejb, peterr voted this post useful.
Old 06-09-23, 03:25 PM
P
Thank you. I think it is the difference in the devices.
The obvious was under my nose.
Old 06-10-23, 05:56 AM
D
Received 10 Upvotes on 9 Posts
There are some 1.5V rechargeable Lithium batteries available, I have no experience with them though.
