I use a USB Cable from my EMERGENCY radio to plug into a two-prong AC Wall Plug to provide constant power to the Emergency Radio Battery.
My problem is the USB plug into the AC Wall plug is loose and constantly falling out of the Wall Plug....I've gently tried to bend the shape of the USB plug for a tighter fit but I'm afraid of bending it too much. Short of a spot of Crazy Glue where the USB and AC Wall plug meet, is there another creative way of achieving a tighter fit of these two?
ALL and ANY advice is GREATLY appreciated! (My Thanks will be your addition to my WILL! (I'm 86 and have terrible health!)
I use power strips set on a table (easy to reach without bending over). I leave things plugged in and use the switch on the power strip. Less wear on the plug/outlet and my body. They are available with built-in USB power so I can use a USB-to-USB cable.
I do the same. I do NOT plug-in and out which could lead 'wear and tear' quickly.
You could buy anywhere, i.e. Home Depot, Lowe's and even Amazon from which I mostly purchase those things because of less-hassle to find easily with Prime-Membership.
I suspect the receptacle's prong contact jaws have lost their clamping (tension) force causing the device or cord plug to back-out or fall out. The contact jaws will weaken over time after repeated use.
UL approved devices require certain standards for residential and commercial use with hospital grade devices receiving the most rigorous requirement where receptacles are subjected to four angular pulls with a 10 lb. weight and must retain a 4 oz. weighted pin for one minute in the ground contact.
I think the OP probably needs to replace that problematic receptacle...
We, the family did that, but it was a quick job to have done. Luckily, my son who is handy working around the house helped the family out, but it took the time in my recollection. Because, the wires inside was so brittle, even a slight touch to work it around due to the age of the house built in early to mid '60s. We have been living in this house since our marriage. It's one of older to old house in our, all of the neighborhood. Almost, we needed to call the professional help for this type of work, ... but if some of the relatives could help you out, it must be GREAT.
Hello:
I just got 'HP OfficeJet Pro 8020e series' this morning and the PC with Windows 7, I did 'test' paper along with 'alightment.' Both went smooth with no issues at all. However, I'm NOT able to print any programs, e-mails, words and some of web-pages which I want to print.
On the other, the PC with Windows 10 is no issue at all, ... any printing jobs is fantastic results.
Since there is no CD in the box and no reliable 'download' for its driver, even though I searched for it in my suspect 'driver' is something wrong for Win 7.
btw) both the PCs, win 7 and win 10 got 'self-installed' driver when I attached the printer-cable into the PCs.
Any help would be really appreciated. Read More
My 2 years old LG Gram 17" laptop with Windows 11 always had VERY low sound but the other day I noticed inside my Vmware which has XP-PRO the sound was perfect so I realized the speakers are ok and it must be the driver. Checking the device mgr it says that I have the right driver when I ask to update the driver. Any ideas what to do next. LG site is very primitive when it comes to ask for help
Thanks
Read More
