How to change CMOS battery
Old 04-22-24, 09:17 AM
B
Does anyone know the correct way to change a CMOS battery on a Lincs 17514 MB? The battery socket doesn't have a tab to pop it out. Rather than force it out, I was wondering if there is a secret method.
Thanks.
Old 04-22-24, 11:28 AM
P
Received 2,224 Upvotes on 1,985 Posts
Usually there are little tabs you have to push back to release the battery. Is your battery soldered in place?
Old 04-22-24, 11:52 AM
B
no tabs. that's why i posted this. not soldered.
The attached image shows a contact at the 9:00 position of the image but it is not a tab.
Old 04-22-24, 12:39 PM
T
Received 76 Upvotes on 69 Posts
I'm pretty sure a small flat head screwdriver under the right side of that battery will lever it up past those 4 plastic tabs. It might help as you are twisting the screwdriver to use a finger to push back slightly on one of the right side plastic tabs to give it someplace to release. The battery might even slide a smidge to the left to again initiate it coming out past the tabs.
Old 04-22-24, 03:32 PM
P
The picture is low resolution and doesn't show the battery holder well enough to help much. It looks like the style shown below. Use a small flat blade screwdriver like Tumble mentioned to pry back the contact/retainer tab.
