Computer clenup!!
Old 07-21-01, 07:51 AM
Guest
Question
I don't know much about computers. I got a Compaq presario
that every now and then will lock. some advs me i should clean it up. how can i go by doing this? (compaq presario 5304) HELP!!
Old 07-21-01, 08:12 AM
Lightbulb
Need more info about your Presario system:
Operating System? 95?, 98?, etc.
If so, find following information(Memory(RAM), Processor type, Hard disk space available)via the following menu hops:
START > Settings > Control Panel
Double click on "System" Icon. Select General Tab at top, will show processor type, etc.
Performance Tab will show Memory, system resources %available, etc.
Double-click "My Computer" icon on your desktop. Right-click once on your hard-drive(C. Left-click once on Properties. This should show you available space on the drive.
If need be I'll point you to Scan Disk and Disk Defragmenter, but first:
What're you using when system locks up?
-Chris
Old 07-21-01, 08:14 AM
Sorry about the smiley face - that was C colon! The standard letter for most harddrives!
-Chris
Old 07-21-01, 12:46 PM
bigmike
Cool Compaq
You also may want to contact Compaq. I saw on CNN that there is a problem with the Presario OS and they have have a fix for it.
Old 07-21-01, 04:27 PM
D
http://www.compaq.com/support/
this is the compaq support site, check them out.
Did you have this problem from day 1 since you got the computer ? Does it happen only when using a perticular piece of software ?
If it was ok at the beginning that what was installed / updated/uninstalled since the last time it worked fine to present ?
Old 07-22-01, 08:00 AM
Talking The roof the roof is on FIYAHH!
nice animation d-says it all!
-Chris
Old 07-23-01, 06:07 AM
Guest
yes! to your question dkerr. since day one. and it does this
when i do anything. some time works like a champ and some time it become mad.. i will give compaq tech. support a call.
Thanks guy's!!
