Index.dat files
Old 08-19-01, 10:34 AM
BGH
BGH is offline
Angry
I just went through the process of cleaning up my hard drive only to learn that everything internet related cleaned is still listed in index.dat file. I downloaded spiderbite will this clean the index.dat file? Or do I have to access dos?
I have seen a few sites that include information on adding steps in dos to always delete the index.dat. Is this the only way?
Thanks in advance.
Old 08-19-01, 04:33 PM
Member BSB recommends a program named spider. Try this forum or hints tips and tricks.
Old 08-20-01, 04:45 AM
BSB's Avatar
BSB
BSB is offline
yes, spyder will clean the index.dat files. 2000 has a slick way of cleaning them aswell if you are unsure if you want to intall a program to do it for you. you can also see a similar process at http://www.hardwarehell.com
Brian
Old 08-20-01, 06:07 AM
BGH
BGH is offline
Question Follow-up question
I did download spiderbite. But when I opened it, two programs were available, spider and spiderbite. Spiderbite couldn't run, so I ran spider. Spider showed me the list of files and I reviewed them. There was nothing I wanted deleted, so I ended there. If I wanted to delete anything, would one of the other options in Spider have done it for me?
Thanks again!
Old 08-20-01, 08:39 AM
BSB's Avatar
BSB
BSB is offline
Unfortunatly there is no way that I know of to selectivly delete index.dat internal files. when you run spyder (syderbite is only used by spyder) you click on the ambulance icon after decide if you want to delete the dat info, will tell you the spider has bitten, do you want to restart.
brian
Old 08-20-01, 09:11 AM
BGH
BGH is offline
Talking
Thanks Again!!
