scanners
Old 08-19-01, 03:06 PM
hvac4u's Avatar
I installed my computer scanner, and it won't let me do anything with it, everytime I click on the icon, it says that it will install it again. So it is installed, but I cant do anything. It's a 600CP Mustek.
Old 08-20-01, 04:41 AM
BSB's Avatar
BSB
BSB is offline
sounds like it is missing some thing in the install.
(thank you captian obvious!) Have you checked for updated drivers? and has your OS been updated?
Brian
Old 09-01-01, 12:53 AM
Guest
It sounds like you are clicking on the install Icon for your scanner. Usually you can access your scanner through an image program like Adobe Photoshop,PhotoSuite or any other. Once you have one of these programs running go to File then Import and select your scanner from submenu. Scanner access application should then start. Also make sure your Twain driver(s) has been installed.
Joe
Old 09-02-01, 03:25 AM
the_tow_guy's Avatar
Received 53 Votes on 43 Posts
I use Adobe Photoshop LE and iPhoto Plus with my Mustek 600 III EP Plus. To use the scanner select <File>, <Acquire> (or <Select>) and the scanner window should open.
Second the idea of checking for updated drivers; got updated driver for mine a while back and performance was much improved.
