main display adapter problem
's Avatar
01-23-02, 09:48 PM   #1
display will allow 16 colors only, checking thru windows plug & play shows, display adapter ok code 24. Problem is with the main display adapter & then display will work. possibly tied in I don't know, but also when going thru windows plug & play, computer is reporting 2 acpi. system bus types? code 2 help please
mrhoadar's Avatar
IL
01-24-02, 05:40 AM   #2
It sounds like a driver issue. Check the Device Manager and go to the Display folder. Does the card it thinks you have match the card you actually have? If Windows can't find a device driver for a display adapter during plug-n-play it simply uses the default windows VGA driver, which is 16 colors.
If the Standard VGA or SVGA driver is in place you will need to reload the correct driver for your card manually.
2000's Avatar
01-24-02, 06:46 AM   #3
Although I don't understand: "Problem is with the main display adapter & then display will work" this is a fair list of Windows device error codes http://www.dewassoc.com/support/win98/devcode.htm
Resolution BIOS update - reinstall driver.
Before updating the BIOS; in addition to contacting the manufactures web site, it would be wise to seek Bigmikes or Mrhoadar consul, relinquishing minimal relevant information such as brand of computer, BIOS version, and windows version. Err here and you create paper weight.
