printer wont print
Old 02-10-00, 04:19 PM
G
Guest
Unhappy
i have a cannon bjc4300 printer. it goes through the motions as if its printing but doesn't. acts as if the cartridge is dry, but printer behaves the same way when cartridge is replaced.
any suggestions
thanks
jt
Old 02-21-00, 07:46 AM
G
Guest
Cool
did ya take off the little orange tape at the print head?
you also might wanna try to replace the entire cartridge, although it costs about $50
Old 02-22-00, 08:07 AM
G
Guest
Post
Try this first...If you had another printer installed prior to this one - it may be conflicting with it. Delete the old printer's driver if you no longer use it. If this still isn't the problem - reinstall the driver and check the settings. If you do not have the software you can probably get it free from the Cannon website - also, I am sure they have some online support for you. They want their product to work.
