the NTFS
Old 04-29-02, 06:45 AM
doc-2-27295
the NTFS
I have formated a 6 gb hard drive but it will not let me install win 98, because of the NTFS files. What can to get the hard drive to install windows ??.
Old 04-29-02, 08:38 AM
bigmike
Cool Format
Pop in your 98 startup disk and go to Fdisk. You want to remove any partitions and then format again.
Old 04-29-02, 04:47 PM
Bryanx0a0d
If you FDISK you will destory all data on that disk. Try reformatting the partition using FAT32.
Are you trying to setup a dual-boot configuration with a later OS?
Old 04-29-02, 06:07 PM
bigmike
Cool Bryan
Now I took this as if you were formatting the drive as a single drive, if it is NTFS on one partition and FAT 32 on another then do what Bryan says, if not then just delete the NTFS partition and format FAT 32.
