rmdr.iq not found
Old 04-29-02, 07:34 PM
rickwhoo
rmdr.iq not found
every time i turn computer on this "ERROR rmdr.iq not found" i click OK and everything works fine.
Old 04-29-02, 08:48 PM
BSB's Avatar
BSB
BSB is offline
rmdr.iq is a file used by HP's registration program for the OfficeJet 600 series. The error appears seven days after installing or reinstalling the printer drivers and you declined to register online.
To correct the error, edit win.ini and remove the line
(You can use Notepad or go to RUN and type in sysedit and click OK. Click on the Win.ini and remove the line and then go to FILE and click on SAVE. Close the Sysedit and reboot computer for the changes to take affect).
"c:\progra~1\hpoffi~1\register\remind.exe" from the "load=" line of the [windows] section.
Hope this helps you out and let Wayne or me know if it does or not.
Brian
p.s I cheated and found another forum that had this answer. Others report that it works, give it a try and let us know if it does.
Brian
Old 04-29-02, 09:26 PM
rickwhoo
thanks, it worked.
