Hard Drives
Old 06-02-00, 09:33 AM
G
Guest
Question
Hi, does anybody knows the dos command to copy everything from an old hard drive to a new one? Thanks.
Old 06-02-00, 10:29 PM
G
Guest
Post
As long as the drives are the same size you can use X copy
I use a program called Drive Copy. It works great and is relatively inexpensive.
Old 06-03-00, 06:26 PM
G
Guest
Post
You can use xcopy in the following format, starting the command at the C:\ prompt in DOS
XCOPY C: F: /S
Put the letter name in place of F in your command.
This command will copy all files on C:\ and all subdirectories - except those subdirectories that are empty.
