Won't Print in Color
I have a HP Deskjet 672 printer. It suddenly quit printing in color. I opened printer properties and aligned the cartridge. The lines were red. I ran the clean cartridge and the lines were colored. I ran print a self test and the page had color. I have color set on automatic and the gray scale box is not checked. I replaced cartridge and ran the same procedure and still no color. I used a Q tip and cleaned the old cartridge. Any help would be appreciated. Thanks
Robertk
Robertk
Sounds like your HP needs some pro help...call the HP help desk..they are some nice people and might can help...
Are you sure that you removed the seal tape on the replacement cartridge prior to installing. I didn't once on my H-P printer, and that was MY color printing problem. The first one may be empty. Good Luck!
Thanks for the responses. I found my problem. My default for the printer had changed. I corrected that and printer works fine and in color. I appreciate the help.
Robertk
Robertk
Your problem is that it is an HP!!!!!
Buy a Canon and have no mors problems!!!!!!
Previous Thread
Next Thread
