No dial tone?
I have an e machine that is about 10 months old. My son was online one evening when a storm came through. The computer is plugged into a surge protector, but I still have asked him to turn the computer off when it is storming. Since then when I try to log onto the internet I get a message saying there is no dial tone. I have checked the phone line and it is fine. After unplugging the phone line a couple of times from the back of the computer it finally dials. What could be causing this? Is there a way to fix the problem? I'm tired of plugging and unplugging the phone line.
Try reinstalling the modem drivers. I am not really up on E stuff but modem is a modem. either the drivers are defective or the modem is. Replace the modem. Kisses from God can do funny things. I have seen it blow mdoular phone jacks off the wall or just blow a fuse in the VCR.
1st: you did have the phone line plugged into the surge protector, too? Not just the computer? If you aren't using a surge protector for the phone line, the modem connections may have been damaged.
2nd: If you did have the phone pluuged into the surge protector, buy a new protector.
3rd: It may thing more than the connections were damaged. New lines may fix the problem.
I had this problem occur when a storm came through last spring. The lightning blew out my USR 56K and my replacement 56K will not stay connected for more than a few minutes since that time. I can use use an older 1.2 GB HDD and connect with a 33.6 and stay connected all night long. What a hassle!
The motherboard was obviously also affected by the lightning surge. I can't stand having to buy another motherboard! The Tyan Trinity AT is a good board, but this one needs replaced.
More than a Carpenter
http://www.carpenter.cjb.net
