copying slides on a scanner
Old 09-30-00, 06:01 AM
Guest
Unhappy
What kind of an accessory do I need to scan slides with my Canoscan FB620U scanner? I'm thinking it may not be possible but hoping someone can help out.
Thanks
simonmeridew
Old 10-01-00, 07:31 AM
Guest
Post
There is a device shaped like a triangle,
that redirects light from the emitter,around
and through the slide. You might be able to make one out of plastic or strong cardboard
painted white.
Old 10-04-00, 09:29 AM
Guest
Post
Your best bet here is to look into the purchase of either an external slide scanner, or check if your scanner supports an optional slide scanner.
I purchased a USB scanner for less than $100 recently that came with a free slide-scanning adaptor.
Good Luck!
Old 10-06-00, 11:30 PM
Guest
