Random lock up's
Old 11-15-00, 11:53 AM
Angry
OK one of youse guy's give me an idea here...
UMAX Notebook
300 MHz AMD K6/2 MMX
48 megs ram
4 megs video/ On board SE/Virge/MX
Windoze 98 SE/ Typical install.
IE 5.1
Outlook express 5.0
I get random screen locks, doesn't seem to be attributed to heat, processor usage or program. I can be in Express mail or just opening a program off the desktop. I am on a network but have disconnected and still get locks. The only pattern I can discern is mouse movement (touch pad) seems to maybe cause it. Although it's not always with mouse move, could happen just sitting here. This one's got me whipped, I've formated three time's even did a "/mbr" from Fdisk to redo the master boot record. Thought IE 5.5 could be culprit but formated and just installed 5.01. Sooooo HELP
Old 11-15-00, 03:57 PM
Post
that's a tough one. Assuming irg's are shared correctly I would try to update video drivers first. A bad stick of ram could also be the culprit.
Also try the following tweak if you havent' already. I feel it greatly increased the stability of all my machines, takes about 30 minutes tops.
Files in question:
vcomm.vxd
vdmad.vxd
configmg.vxd
vdd.vxd
vmouse.vxd
ntkern.vxd
vflatd.vxd
Windows 98 Drivers Bug
The MS Windows '98 installation does not install some vxd files in your system directory ( what did you expect ? ). To resolve 20 to 50% of the system errors in any Win98 build ( including the final release ), extract these vxd files manually from cab 47 and 48 into c:\windows\system and c:\windows\system\vmm32 The following files should be extracted:
vcomm.vxd, vdmad.vxd, configmg.vxd, vdd.vxd, vmouse.vxd, ntkern.vxd, vflatd.vxd.
Extract these files to both directories and reboot. Your system will love you for it .
This bug in the installation of Windows '98 is not reported or confirmed by Microsoft, and there seems to be some controversy on whether extracting the vxds really improves anything. Judging by the hundreds of positive replies I'm getting, it fixes numerous problems in the operation of Windows.
VMM32.VXD is a generic, slower MS driver, build at Windows installation. Some of the drivers needed on your system, including these vxd's are supposed to be part of VMM32. As it turns out, however, it generates numerous problems with most PCs. Extracting the vxd's to the system and vmm32 directories provides for loading the newest drivers separately. It has been proven to fix lockups, error messages at start-up, VMM errors, erratic/slow mouse movement and many others..
To check if you need the vxd's for yourself, look in the Driver File Details tabs in your Device Manager ( Control Panel > System > Device Manager ). If you find entries containing 'vmm32', there's a good chance you need to extract these manually. For example, in my Modem Driver details, I had " C:\WINDOWS\SYSTEM\VCOMM.VXD (VMM32) " before, and just " C:\WINDOWS\SYSTEM\VCOMM.VXD " after I extracted the vxd's.Note: if you're upgrading, rather than doing a clean install of Windows '98, you might have the old, Windows '95 vxd's in your system. You can check the file versions ( they should be 4.10.1998 ) if you want to find out whether you need the vxd's
DLLs replaced by Windows '98
Microsoft's new OS seems to disable third party, newer DLLs in favor of older, baseline MS versions. The Windows setup routine detects newer DLLs ( which usually originate with MS and are distributed to competitors for use with its products ), and moves them to another folder, installing earlier MS versions.
To fix some of your programs, relying on the newer DLLs, after upgrading check the Version Conflict Manager, which is buried deep into Windows, and usually not found by users. The Setup does not mention the replaced DLLs either. To find the replaced DLLs, click Start, Programs, Accessories, System Tools, System Information, Tools, Version Conflict Manager
Note: To my knowledge, the Version Conflict Manager will not detect any replaced DLLs after the initial Setup of Windows.
Please give me feedback on which DLLs have been replaced in your system, and what problems have been fixed by restoring them. Some of the replaced shared files are:
DLL Win'98 ver. Replaced Ver.
cabinet.dll 1.0.601.4 1.0.603.0
comcat.dll 5.0.1600.1 5.0.1601.1
dllhost.dll 4.71.1718.0 4.71.2612.0
msconv97.dll 1997.3.12.0 1997.4.2.0
ole32.dll 4.71.1719.0 4.71.2612.0
twain, twain32.dll 1.6.0.1 1.6.0.3
W95inf32.dll 4.71.16 4.71.17
Win98's installation problems
Occasionally, Win98 will not give your computer the files it needs or replace older files during installation. This will make it default to a slower vxd called vmm32.vxd in place of the true files.
To see if your missing any files or have older versions provided by Microsoft right click on 'My Computer' , select properties , and then device manager.
Go to the properties of each device on your system and select 'Driver' then 'Driver File Details'
If there are any file references that say "Unknown" at the version text you will probably see this for what driver it is using: C:\Windows\System\vmm32.vxd (configmg.vxd). What this means is that you are missing the file in the parenthesis.
To get the missing file and to update older files go to your directory that contains the Cabinet (*.CAB) files to Win98. Click 'Find' on the start menu then 'Files or Folders'. Where it says 'Containing Text:' type the name of the file, then select the directory where the *.cabs are and search then simply extract them to where they belong.
Most missing files are in win98_47.cab & win98_48.cab
Also get the VCOMM.VXD file for your Logitech mouse to fix a few problems. This is usually located in Win98_49.Cab. Put it in your C:\Windows\System\Vmm32 directory.
Old 11-15-00, 05:39 PM
Post
Going to start doing this now. I was thinking since it's a laptop, that the CPU may have got hot at some time or over a period of time and is failing. Or memory, same thing. Although the CPU sit's upside down in the bottom of the laptop and has a good size fan and heat sink on it. Memory too is well sinked. Unit is a 97/98 and I am the second owner, the guy swapped me for some other electronics he wanted. This had been setting for about 10 months because he gave up on it. New LCD display but battery is shot. Anyway, here we go...
Old 11-24-00, 09:25 AM
Post
Yes, a tough one. I've had some virus scanner programs cause this kind of problem......especially McAfee. And legacy software could also be the culprit, they're famous for not releasing the memory and causing conflicts.
But, because it's a laptop, I suspect it's a temperature problem......which may well be a design flaw in this case.
There is some temperature monitoring software available free at TechTV and PC World web sites. Sorry, but I don't remember the names of the recommended ones.
Good Luck...........
Old 11-24-00, 10:44 AM
Cool
Well this turned out to be an overclock issue. After working on this thing for two weeks installing/formating/memory changes/registry for some reason I got the idea to check the dip switch settings in the computer. He had sent this in a few months ago to have a broken LCD replaced and a 300 MHz processor (instead of the 266) installed. Well the guys at the factory had the core voltage at 2.8 volts and the actual setting on the AMD 300 is 2.2 volts w/an IO of 3.4. Well it only takes .7 volts to trigger a transistor and a processor is not much more than a high speed switch. So it was running hot, even though there was a good fan etc on it the cpu itself was still running to much voltage and causing the hangs. After resetting the IO/Core voltages back to factory specs the bloody thing has been working perfect for over a week. Can't see the trees because of the forest...
Trackbacks are On
Pingbacks are On
Refbacks are On
