Download music from Dish Network
lime's Avatar
06-10-02, 02:08 PM   #1
lime
Can I copy music into my computer from the digital signal on my dish so I can burn discs to play in my car? How?
trinitro's Avatar
06-10-02, 02:48 PM   #2
I'm not if it's "legal" to do so, but yes, it's fairly simple. Just use the RCA outputs from your receiver, use a converter cable and plug them into the line in connector in your computer, then use a recording program (like total recorder) to record the sound (wav format, needs like of space on the hard drive). You can then edit the file if you want to, and use Adaptec or Nero to convert it into a MP3 file, and burn it. Or you can simply burn it as a Wav file, and play it in any CD Player. One thing you have to remember is that it records in real time (a 30 minute song actually takes 30 minutes... .
bigmike's Avatar
06-11-02, 11:30 AM   #3
bigmike
Adapter...
The adapter Trinitro speaks of is an RCA to 1/8" stereo phono. You will most likely need a patch cord from your Dish to the puter so get a six foot, 10 foot whatever you need that has male RCA's on each end. The adapter to the computer will be about 2' long and you should be able to get it with female RCA's. If not you will need barrel connectors to go between the patch and the adapter.
lime's Avatar
06-11-02, 12:26 PM   #4
lime
Thanks, to both of you.
