Problem with CD writer
Jonre's Avatar
New Member
06-24-02, 07:49 PM   #1
I've recently upgraded to Windows XP. I love the XP, but the compatability issues I'm running into are a nightmare.
Here's my priority: My burner is not able to write data.
My CD-ROM is a Samsung CD-R/RW SW-208F. I am able to play CDs, play previously-burned CDs, and install retail software with the drive, but I'm having problems writing to it.
My main concern is that I want to back-up data from my C drive onto CDs. I've tried different methods:
1) Using Microsoft backup (error message says the file name I've chosen is incorrect or I don't have access to the drive).
2) Going into Explorer and dragging folders from the C drive into the D drive (looks like it's working, but when I check afterwards, the disk is empty).
3) Also within Explorer, selecting a data file, then clicking on COPY to another folder, and selecting the D drive as my destination. This method really looks like it's copying the files properly, with a little window and a progress report bar, then is says the data was transferred. Of course, when I check, the disk in the D drive is empty.
I've tried using different manufacturers' disks. I've gone to the Samsung website to look for drivers. I've tried the hardware troubleshooter in XP.
What I'm on the verge of doing is buying a new burner - with Nero software - and installing that. Can I assume this would fix my problems??
Any other ideas?
Thanks!
Jon
Gary Tait's Avatar
06-25-02, 08:36 AM   #2
Gary Tait
You could downlaod an try the Nero demo version, and see
if that works or not.
bigmike's Avatar
06-25-02, 12:24 PM   #3
bigmike
Nero
Go get Nero, you have to have burning software to burn... www.nero.com
Wallpaper's Avatar
06-25-02, 07:10 PM   #4
We started using Nero in XP and ran into a problem. Some crazy error came up stating that some other program was using the IMAPI engine and we were doomed. If this happens to you, go to Start->Run->type in..... msconfig-> go to the Service tab. You should find something labeled IMAPI CD-Burning services. Uncheck it. If you figure out how to make Microsoft's built in burning program, this needs to be checked to work. You can also uncheck a bunch of resource hogging stuff in this window if you are somewhat advanced.
