New ironwood deck looks very old :(
Old 07-28-02, 06:45 PM
AJain
Hello, we recently got an ironwood deck made. We sealed the wood with 'Superdeck' sealer prior to the deck assembly. For some reason, now the deck surface looks totally patchy. A little bit of water causes the patches to appear and then they tend to stay there. Also, the wood color looks kind of faded.
Any advice would be greatly appreciated. Thanks
Anu
Old 07-28-02, 07:40 PM
Doug Aleshire's Avatar
Ironwood Deck Problem
AJain,
You apparently used a great product designed to be used on ironwood but is it possible that a recoat is necessary. It sounds as though it needed a second coat or there wasn't enough put on.
If you stained it, a second coat might had been needed but you'll never have to touch it again.
Good Luck!
