Porch Quick-Fix
Old 04-12-00, 12:16 AM
Question
My front porch, which is made of 2 1/4' boards, is about 2/3 exposed and is getting pretty soft. I'd like to completely rebuild, but I cant afford to for a couple more years. As a quick-fix I'm thinking of covering the exposed areas with 1/2' plywood and painting it. Is this a good idea? Also what can I use to seal the seams between the plywood sheets?
Thanks in advance.
Old 04-12-00, 05:52 PM
Post
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>front porch is made of 2 1/4' boards, is about 2/3 exposed and is getting pretty soft. <HR></BLOCKQUOTE>
I'm unclear on what you've really described here!
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>As a quick-fix I'm thinking of covering the exposed areas with 1/2' plywood and painting it. Is this a good idea? Also what can I use to seal the seams between the plywood sheets?
<HR></BLOCKQUOTE>
I don't recommend plywood to the exposure even if painted. Fiberglass and resin maybe, but not paint.
MTAC - Van Buren,MO
www.carpenter.cjb.net
Home repair & Construction
"Where the character and work are always upright"
Anything worth cutting down a tree for, is worth doing right.
www.toolreview.cjb.net
