Building Inspector
Old 04-30-00, 05:51 PM
Post
To find out how big a post one needs to have and how deep one needs to go for a deck that is going to be over 10' high. Do I call the city builder inspector to get this info on the building codes for building a deck...
Agian Thaks in Advance
BG
Old 05-05-00, 08:09 PM
Post
Lots of people would choose to use 4x4 for this, but a 4x4 that long will twist badly in a short while. I would recommend 6x6.
As far as the depth, your local code will prevail. Call the building code enforcement folks and they'll give it to you straight. You usually need to provide a drawing of your project to them for a permit anyway.
MTAC - Van Buren,MO
www.carpenter.cjb.net
Home repair & Construction
"Where the character and work are always upright"
Anything worth cutting down a tree for, is worth doing right.
www.toolreview.cjb.net
Old 05-07-00, 05:35 AM
Post
Yes, contact your local building permit department. Take a drawing of your deck with you. Good Luck
Jack the Contractor
