stringers
Old 07-13-00, 01:10 PM
Post
I am cutting stringers as you suggested i.e.
7 " riser 12" tread I am using 2 by 12's
how do I attach them to 2x10 ledger.
Old 07-13-00, 11:01 PM
Post
Simpsom LU210's would work just fine
Old 07-14-00, 09:55 AM
Post
you can l bracket them to the face of the header or slip them under the header and attach to the sides of joists.
Old 07-15-00, 10:19 AM
Post
Or use a pressure block. It's the cheapest and quickest way that I know.
A pressure block is a scab attached to the ledger and then the stringer is nailed or screwed to the block and toenailed to the ledger.
More than a Carpenter
http://www.carpenter.cjb.net
Old 07-15-00, 11:31 AM
Question
I also am about to attach a stringers made from 2X12PTs. My rise is 6.5inches and my joists are 2X8. There is very little nailing/screwing space for attaching the stringers to the 2X8. I was thinking of attaching a 2X12 to the 2X8 to allow for more space. Any thoughts?
Old 07-15-00, 11:36 AM
Question
Is 6.5 inches okay for rise? My height is 39.125 inches; it was the only way to get a consistent rise based on 6 steps.
