too close deck boards
Old 08-07-00, 10:44 AM
Question
Some boards on my deck are too close together and water can not drain through them. should I just drill holes for drainage where puddles build up?
Old 08-07-00, 11:56 AM
Cool
That will work, but for a better look, you might want to consider running a skilsaw blade along the cracks between the boards set a depth that will not cut your joists. Good Luck!
Old 08-16-00, 05:50 AM
Post
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by OldGuy:
That will work, but for a better look, you might want to consider running a skilsaw blade along the cracks between the boards set a depth that will not cut your joists. Good Luck!<HR></BLOCKQUOTE>
