Setting a post
Old 09-21-00, 05:20 AM
Post
We want to attach a post base to an existing 12" dia. footing. What type of fastener should we use and how long. We are going to drill in with a standard masonry bit.
Old 09-21-00, 01:50 PM
Post
When you say base plate I thinnk you mean the plate that the post will set on. If so, go to your home improvement store and get two or three expansion bolts. Either wegies,
or tiger bolts. I think they use a 3/8 bit.
Instructions are on the bolts. drill hole, slide bolt into hole, tighten nut, and your all done. Should take aboout 10 minutes.
Old 09-21-00, 02:05 PM
Post
Thanks, we'll give it a shot.
