Material Costs for 10 x 12 Deck
Old 03-13-03, 04:08 AM
SamFromBhamAL
I want to replace an existing deck and would like to know the approximate cost for the building material. I live in Birmingham, AL (Jefferson County) and the new deck will have the same dimensions as the old deck, which is 10 by 12 and is 10ft 6in off the ground. There is a patio under the deck (concrete slab) that the supports will rest on (that's the way it is currently) and four concrete footers will need to be poured for the step landing. I will be using treated pine.
Thanks, Sam
Old 03-13-03, 08:56 AM
Take a sketch of what you want to do to a local lumberyard. They can quote the cost of the material for you. They can also show you products that will reduce or eliminate most of the maintenance involved with a deck, prolong the life of the deck, and suggest methods of installation that will improve the visual appearance of teh finished deck.
