Cedar Deck Cleaning Question
Old 04-05-03, 04:28 PM
amanda14
Question Cedar Deck Cleaning Question
We have a 2 yr old cedar deck to which each year I have treated with Cabot Clear Solution. I must say I am a little disappointed since it is now peeling in some areas and I can see the grey underneath. I guess this can be attributed to the harsh winter. Anyway, can I pressure wash a cedar deck, and if so, do i need to scrub it down as well? What is the best do clean a deck or scrub if necessary?
Thanks-Matt
Old 04-05-03, 09:23 PM
MeffaDawg
Behr deck cleaner and brightner does a good job of cleaning decks. I put it into a garden type sprayer and spray in on and let it sit for 10-15 minutes before scrubbing it down with my deck brush. You can then pressure wash if needed. I believe the main ingredient is OXALIC ACID.
I have 2 cedar decks and I've used it on both with great results. I used the product as I described then pressure washed and the deck looked like the day I put it in (6yrs ago).
Here's the url to the product, it's available at Home Depot.
http://www.behrpaint.com/cgi-bin/db2...&W19=Y&base=63
