Deck Slope
Deck Slope
I'm wondering what the standard sloping for a deck should be to ensure proper water drainage. I will be sloping the deck in line with the decking surface, i.e. along the length of the deck boards. It will be 16' long at the max, so I was thinking 2" across the full 16', but that's a complete guess. Any thoughts?
Thanks.
Thanks.
aaronr,
I concur! Deck sloping is not needed...it's an outdoor item and a 2" drop in 16" feet will definitely not feel right to you and your guests!
Sloping a deck 2" that is made to walk on, place furniture on will not avoid the required proper maintenance to keep it looking good! If you are trying to avoid this, better think about an alternative to a wood product.
Good Luck!
Good Luck!
Like the guys are telling you -- decks are built level. Runoff is simply not an issue. The water will fall between the deck boards. I will BUILD any deck that a customer wants. But the only deck I will ever put in my yard will be a composite. I simply don't have time for all of the maintenance that is involved with a wood deck. There are about 35 composites on the market right now. Pretty sure you can find one that you like.
