Deck Cleaning. Pressure wash or chemical clean?
Old 06-12-03, 05:01 AM
Performin Norman
I've used both in the past and have had good success with both. My old house had a sun deck where a pressure washer was easy to use. My new house has a deck that is way up there and I hesitate to try to use a pressure washer.
What method do you guys prefer?
Thanks in advance for your responses.
Old 06-12-03, 05:12 PM
fewalt's Avatar
Norm,
As you can imagine, pressure washers and ladders don't mix!!
A two story deck does present problems - the deck and rails can be done okay. But the supprting posts and skirt boards are the problem.
The Pros will either use scaffolds, a cherry picker, or an extension wand (see if you can rent one).
fred
Old 06-12-03, 07:34 PM
Performin Norman
Frank,
Thanks for your help. I appreciate it.
