How to remove stamps from wood before staining
Old 07-05-03, 08:52 AM
MarcZ
Any suggestions on how to remove the stamps from pressure treated southern yellow pine prior to staining with a semitransparent coat?
It's a fence. I've attempted paint thinner and denatured alcohol with very little or no success. Do the deck cleaners work on those stamps?
Old 07-05-03, 05:53 PM
Mike Swearingen's Avatar
Cool
Nope. They're indelible.
The best way to remove them is to sand them down with a small belt sander.
Good Luck!
Old 07-06-03, 10:08 AM
MarcZ
Thanks Mike.
Old 07-08-03, 12:44 AM
L
Either turn the boards over so the grade stamps are down, or cut them off. The former may not be acceptable -- you're putting the bad side up. The latter is a lot more waste. Plan accordingly.
But, like Mike says, "removing" the stamps is simply not an option. Sanding -- Not sure whether that will will leave an uglier mark than the stamp or not!!
Old 07-08-03, 08:15 PM
MarcZ
Thanks ,
It's a Board on Board Fence that's already up. Can't cut them out or turn them over. Even if I could, they would then be showing on the other side of the fence. I already have a couple of those that I will just leave be.
Thanks for all your help.
