newbie building deck
Old 07-06-03, 07:51 PM
mjsmitty
hello all, new to this, i'm building a freestanding low level deck approx 12x30ft with one corner cut off. do i need to sink extra posts for the angles or can i use angled hangers or something else? also posts directly in concrete or on top of footings? thanks, mike
Old 07-06-03, 08:39 PM
Doug Aleshire's Avatar
mike,
Your question is going to be based upon how big are your angled corners. If more than 2', additional posts should be installed.
http://doityourself.com/deck/index.htm - Various articles available for review.
http://www.homestore.com/HomeGarden/...stsForDeck.asp
http://www.deckplans.com/plans/pdf/angled.pdf
In regards to posts, options that you mentioned can be used.
http://www.homestore.com/HomeGarden/...nDeckPosts.asp
http://www.hammerzone.com/archives/d...nd/footing.htm
http://www.sustland.umn.edu/implemen..._footings.html
***Good examples of options***
http://www.co.fairfax.va.us/dpwes/pu...ns/deckdet.htm
Hope this helps!
Old 07-07-03, 10:55 PM
L
Received 1 Upvote on 1 Post
Like Doug said, it all depends on the angle and how much overhang (cantilever) you are talking about as to whether you will need extra posts or not.
I would NEVER set a post IN concrete -- either use pier blocks and attach the post to that, or use a post base on top of your footing. Check either Simpson or USP for the post bases. Both are "code approved", and they have virtually the same catalog.
