Fence
Old 07-14-03, 10:51 AM
JP2
Fence
I am trying to install a wooden stockade fence, 6 x 8 with posts that have precut holes. The first two panels went in fine. Here's the problem: There is a slight slope in the landscape. Keeping the fence level, will leave a large gap under it. And I can't angle the fence because of the precut holes. Any suggestions? Thank you.
Old 07-17-03, 03:13 PM
Doug Aleshire's Avatar
JP2,
As you can tell by this link, as an example, your answer is located here...
http://www.avinylfence.com/a_vinyl_f...structions.htm
You need to either by blank posts and make your own holes for the fencing for a raked method, or do a stepped method application. Your choice.
Good Luck!
