my front porch low in the middle
Old 07-20-03, 12:39 PM
Dkodid
I have a small front porch, 4x8 ft. concrete.
My problem is that the center area is lower than the rest causing water to settle. It's approx. 1/8 " lower, maybe a little less. I would like to know if there is a process to level the porch without replacing it.
Any & all feedback would be appreciated.
Thanks in advance.
Old 07-20-03, 01:38 PM
C
There is some sort of leveling compound you can use for concrete. I don't know more, but someone will be along to cover it in detail for you.
Old 07-20-03, 06:14 PM
Doug Aleshire's Avatar
Dkodid,
As chifte mentioned there are products available but costs do vary. There's a couple of products available for what you are looking for at Home Depot
One is Vinyl Concrete Patch by Quikrete to be used with a Concrete Bonding Adhesive to ensure a sound adhesion. This can be feathered. Cost is about $10.00
The other which I am not sure of it's exact name but is located in same area of store is about $22.00 - I beleive this has fiber reinforcement added to it.
Hope this helps!
