deck squaring
Old 07-21-03, 07:07 AM
Rick sexton
deck squaring
It has been a long time since I squared up anything, and have forgotten the formula for squaring up my front porch. Any help would be appreciated, the porch size is 12x16.
Old 07-21-03, 11:43 AM
L
Measure diagonally from corner to corner. Then measure diagaonally the opposite corners. Rack the frame as needed to get both measurements the same. When the two measurements are the same, the deck frame is square. (A 12X16 deck will have a diagonal measurement of 20')
Old 07-21-03, 11:55 AM
Rick sexton
thanks
Your help was greatly appreciated.
Old 07-21-03, 09:15 PM
C
Just for reference, the formula you were looking for is the pythagorean theorem, which states that:
SQUARE ROOT (A*A + B*B) = C
where C is the hypoteneuse (longest side) of a right triangle.
In this case, lefty derived the diagonal by doing the calculation:
SQUARE ROOT(12*12 + 16*16) = 20
since 12*12 + 16*16 = 400, and the square root of 400 is 20.
Old 07-21-03, 09:44 PM
fewalt's Avatar
The pythagorean theorem:
In simpler terms just use the 3-4-5(or 6-8-10) method.
Three foot down one line, four foot down the other, and the diagonal should be five foot. Adjust your line(wall) to obtain square.
fred
Old 07-21-03, 10:00 PM
Doug Aleshire's Avatar
fewalt,
That was just a lucky guess, Fred!! (LOL)
Simple method compared to creiter, huh Fred?!
This is the best rule of thumb for making square corners but as lefty said, diagonals should be the same before getting serious on building anything - easy all the way around!
I used the 3-4-5 method alot on foundations. Doing diagonals on wall framing is easy and this works great just before securing your wall sheathing and tilting up the walls. Nothing worse than seeing a crooked wall.
Just some late night thoughts!
Old 07-22-03, 05:11 AM
fewalt's Avatar
Doug,
It wasn't a lucky guess at all.
Norm Abrams has been using it on NYWS and This Old House for many, many years. It's the simplest, most exact method to use.
It's still the "P" theorem. And you don't have to take the square root of anything.
fred
Old 07-22-03, 05:37 AM
fewalt,
I was just teasing! Late night last night!
Good points made regarding it! Thanks!
Old 07-22-03, 02:29 PM
brickeyee
Just be carefull measuring diagonals. they are only equal if the lengths of the opposite sides are the same.
