brick paver maintenance
Old 07-24-03, 08:26 AM
John1262
What is the proper maintenance for a brick paver patio? Aside from adding sand from time to time, should you also add sealant to the patio? Is there a proper procedure to do this?
Old 07-24-03, 08:10 PM
L
Received 1 Vote on 1 Post
What's to seal?? The bricks are porous -- water will eventually run through them. Sand is even more porous -- water will run through that every time it gets moist.
A rubber mallet to keep the pavers level, a bag of sand to replace what erodes out. THAT is your maintenance.
