Patio Covering
Old 08-25-03, 06:07 AM
psifunnk
Patio Covering
I'm looking for a way to cover the railing on my balcony for privacy.
This looks like a building forum, but if anyone has any idea's.
I live on the top floor of an apt complex and bldg across is pretty close, not to mention the rental office is there.
I have hung bamboo shades from my roof I bought from Lowes. They are 8 footers(biggest) and only lay just over the rail. I need something that I can put on the rail itself to close up the gaps.
Thanks again.
Old 08-25-03, 08:07 PM
Doug Aleshire's Avatar
psifunnk,
Easiest thing I can think of is doing the same as you did from the roof. Apply the bamboo on the railings, inside application. I would use some metal tie wire so that it can be easily removed. Management might not take it to kindly to using permanent fasteners unles you get approval first. Alternate might be plexiglass (smoke) applied to the inside of the rail sytsem but I realize cost would be another issue.
Good Luck!
