Pouring footings
Pouring footings
I'm getting ready to dig footings for my deck; I'm going to need to go 48" deep due to frost.
Questions:
1. I plan to rent a power auger; otherwise, I'll still be digging next year. Do I need to use one of those round forms for the footing, or should pour the concrete in the hole?
2. I plan to use the quick set concrete, and set J bolts into them. How long should I let the concrete set before beginning to work with my posts?
Questions:
1. Subject to the overriding considerations of your local bulding code: If the soil will maintain its shape and not collapse into the hole, you should be able to let the hole be its own form. You may still need a post hole digger to clean up the spill in the bottom of the hole. From experience, I can recommend that you rent a two-man auger. The solo job will beat you to death, plus it will be a chore to retrieve a 48" long bit from the hole alone.
2. Quikrete's web site recommends waiting 24 hours for this application.
Hope this helps.
Hope this helps.
