Installing a storm door on a Atrium door?
the Atrium doors are like french doors, only one of the opens to the outdoors. Has anyone ever installed a storm door over the "opening" atrium door? If so, how did you do it?
If there is glass in the atruim door, DON'T install a storm door outside of it. I am guessing that any glass in the atrium door is dual pane. The storm door would cause it to overheat and break the seal between the panes of glass. Now you've got a fogged up atrium door, and the only cure is to replace the glass IG unit.
