Deck Plans
Deck Plans
Replacing a deck. I need plans to submit to the building department. I've been looking at Plan Analyst Deck Calculator at
http://www.nwbuildnet.com/stores/ss/pa/pa_deck.html.
Has anyone had any experience with this software? Do you any other suggestions?
Thanks.
Thanks.
Received 7 Upvotes
Hello: Rusty
May be able to find the deck plans in the links below:
Building & Woodworking Links: (Copy & Re-Paste into browser)
http://doityourself.com/wood/index.shtml
http://www.absolutelyfreeplans.com/
http://www.scrollsaw.com/Plan_Index/plan_index.htm
http://www.woodworkersworkshop.com/dcd/Woo...nks/Plans_Free/
http://www.the3house.com/plans/menus/free_top_nav1.htm
http://www.freeplans.com
http://www.woodworking2.org/PlanSearch/search.htm
http://members.cox.net/messman123/Links%20to%20Jigs.htm
http://www.am-wood.com/index.html
http://www.freeww.com/index.html
http://www.furnitureplans.com/
http://handymanclub.com/home.asp
http://www.diydata.com
Regards & Good Luck
Web Site Host & Forums Monitor
Regards & Good Luck
Thanks.
I think I solved the problem. As I want to essentially build the same deck with one minor change, one of the contractors suggested that I take my original house plans (left by the previous owner) and just say I want the same deck with this small change. The contractor has told me that here the building departments are fairly accomodating to the HO as long as they are not doing anything dangerous (this won't be) and are notified so they can inspect.
