Load calculator
Load calculator
Does anyone know of a tool that can help me calculate load for a deck design? I searched google pretty hard with no luck. I basically want to enter deck dimensions, size of wood I'm using and the desired load I can handle and have it spit out post spacing, etc....
Either that or can someone give me a quick refresher on how to calculate load? I knew I should have paid more attention to statics in college!
After quite a bit of searching I found this. Hopefully some others can find it useful too.
http://www.awc.org/calculators/span/...rcalcstyle.asp
I often fool with projects and will find this info usefull.
Here is the link for rafters:
http://www.awc.org/calculators/span/reversecalc/reversecalc.asp
diy.com tip: To eliminate the url tag in forums where codes are not turned on you can uncheck "automaticaly parse links" at the bottom of the page.
Ok, I punched in my numbers and it's saying that I can use 2x8 southern pine if I put my posts every 8' apart(ledger against house and then 8 posts), and then have my joists 16" apart.
Does that sound correct for 100 live and 20 dead on a 16x24 deck?
