Elevated Deck for Spa
I want to build an elevated (9') deck to hold a Hot tub (spa)..
I only want bracing on the 4 corners and it can be attached to the house.. can anyone give me some details on the structure.. I've build deck in past and even to hold tubs but was always able to set posts all in several places.?
HELP???
HELP???
1. Is 9' the height?
2. What is the proposed size of the deck in all directions?
3. What is the size of the hot tub and how much does it weigh?
4. Where will the hot tub be placed on the deck?
All of these questions need to be answered in order to determine what you will need. I'll try to answer this, but you are probably going to need a permit and the building department may have requirements that you should check.
lyjo, BeamoPureEnergy,
We have no idea where you 2 are, or what codes you have to build by, or what sort of snow, wind, or dead loads you have to meet, or what seismic zone you might be in.
And lyjo, "Ground to bottom of lower support 9' " -- where I live, that couldn't be done with wood posts -- code calls for the DECK to be less than 10' above grade.
Best advise to both of you -- go ask your local bldg. dept. They will help you design everything from the bottom of the footing up, in a way that they will approve. (They have to inspect it anyway, so start there!)
