How to build 14" high deck?????
Old 02-28-05, 07:48 AM
brians
Question How to build 14" high deck?????
I have a question. I want to build a deck that is 14" off the ground. This would be 20 ' long (along house) and 10-12 ' wide (perpendicular to house). Decking would run parallel with the house. I have talked to a couple different people and they are all telling me different things.
1. I can't build it 14" because you must have a beam underneath the joists.
2. I can just use joists hangers to attach the joists to the ledger and the rim joist but only if I go 12" OC instead of 16".
What is the correct way to build a deck such as this and what size joists, ledger, etc... should I use? What techniques should I use?
Thanks.
Brian
Old 02-28-05, 08:01 AM
pgtek's Avatar
Received 1 Upvote on 1 Post
Old 03-01-05, 08:42 AM
brians
I couldn't find the page for buildadeck.html.
Old 03-01-05, 09:16 AM
majakdragon's Avatar
They may have changed it to this one.
http://www.handymanusa.com/articles
May have to scroll down to deckbuilding2
Good luck.
Old 03-01-05, 01:44 PM
brians
The answer I got from the reading was that it is ok to attach the joists to the rim joist (beam) with joist hangers.
What size joists do you think I need to span 12' and should I double up the rim joist?
