"Peel and Stick" waterproof membrane?
Old 06-07-05, 09:58 PM
Has anyone used any of these products? What would you recommend for a "peel and stick" waterproof membrane on a plywood deck using trex wearing surface ? Here are some web sites that I found.
http://www.skellerup.co.nz/product_c...roduct/70.html
http://www.mobilehomerepair.com/stickit.html
http://www.protectowrap.com/cat_roof4060.php
http://www.buildingonline.com/news/viewnews.pl?id=3781
http://www.cofair.com/peel_seal.aspx
http://www.gaf.com/General/GafMain.asp?Silo=RES1&WS=GAF
Old 06-08-05, 07:27 AM
I don't understand what you have in mind. Please explain.
Old 06-08-05, 09:13 PM
I need to water proof a deck that is over a first floor room. The deck is the ceiling of the room. The room has drywall and the deck is 3/4" T&G plywood over 2 x 8 joists. The deck is 8' x 30' and is accessed from the second floor of a two story house.
We live in the hight desert of California and average less than 4 inches of rain a year.
Old 06-08-05, 09:16 PM
I want to have the trex "float" on the membrane without any penetration of the membrane.
Old 06-08-05, 10:22 PM
No, the Trex HAS to be attached to joists. It will become your worst nitemare if you don't do that!! And the joists that you attach the Trex to have to be secured as well.
Best thing to do is to cover the roof with EDPM, lay your joists (probably 2X4's layed flat, perpendicular to the wall, so water can flow off of the roof) down and caulk the edges to keep water from getting under them. Use a Dow Corning waterproof sealant -- get it at a local glass shop -- anything less will fail. Then screw the Trex to your joists.
If you don't have room to do it exactly that way, forget the deck!
Old 06-09-05, 04:51 PM
