Wood Measurements - Actual
Old 09-09-05, 06:22 PM
Herrmann22
Question Wood Measurements - Actual
Does anyone have a link to a website where it has the actual measurements of wood? For instance, a 2x8x10 is not those actual dimensions so I am looking for a simple way to calculate my wood measurements. So, if I had the actual sizes of the boards it would make life much easier!
Any help would be appreciated. BTW, I could always take a measurement of the actual board I know this, but I am not in a hardware store at the moment and I am trying to figure a bunch of stuff out tonight if possible!
Old 09-09-05, 08:08 PM
jcs
jcs is offline
Try this link:
http://www.woodbin.com/ref/wood/lum_dimensions.htm
Old 09-10-05, 05:49 PM
simple rules
While that website did give you the dimensions, there was a lot of other stuff you didn't need and may have confused you.
For all "two by" (2x) the thickness is 1-1/2"
Widths are as follows 2, 4, 6 are 1/2 less - 2x6 is 5-1/2"
2x8 and up, sizes are 3/4" smaller hence - 2x8 is 7-1/4
There are a couple more dimensions you need to know for building decks. They are 4x4 - 3-1/2 x 3-1/2
5/4 decking is really an actuall 1" (this is most prevalent, some vary)
"One by" material is 3/4" thick
Hope this helps
Old 09-10-05, 09:12 PM
What am i missing??
What difference will knowing the ACTUAL dimensions vs. the NOMINAL dimensions make?
None, unless you are stacking them.
